can you replace heat control panels w/o removing
dash? The panels that cover the direction sliders and the temp control slider look to have little nuts on the backside ( i bought a nice set on fleabay). I am hoping i can finesse the old ones out and the new ones in w/o taking the whole dash out( that will not happen soon). anyone done this? Thanks for advice/experience with this. Also: learned a valuable lesson yesterday- after removing the bottom plate from my steering column to replace a foglight switch, i just screwed it back together with the top half ..... not so fast! The horn contact ring has to be seated correctly between the top half and the bottom half of the column and if the column is put together just a hair out of place, it can also inop your low beam headlight contact. so, while i was trying to reacquire low beams, the horn kept going off because the ring was too far back and it created hell until i pulled the fuse for the horn. Now that i have been taught how to replace the contact ring- i wont bother the neighbors again. Very touchy area on the 72!.
Good info on the faq on the heater rebuild page. On my 72 I popped the knob ends off the slide arms, removed the screws on the back of the face plates and the face plates push off from behind. Happy trails!
