71bmr02
IIRC the pan on an M10 used in an E30 and in Euro 518s and 520s from the late 70s is also different from the 2002 and E21 pans...
The E30 pan is hard to mistake for anything 2002- it's a multi- piece whatzit with aluminum and steel, so fancy...
But yep, it's an M10 pan.
Hits the subframe in front.  You can clearance it, with some welding.  Gordon did.
To make the E-30 pan fit, I cut 1 " out of the steel portion and 1" out of the aluminum portion.  Welded the pieces and add an extra piece to the right side for extra oil in the left hand corners.  I also welded in a trap door on the left side. so far it has worked just fine.  G
