crosson9
Hi Everyone!
         Replacing the water pump on my 02 and noticed that a bypass cap was used to block off one of the outlets. What was used was a 3/4" cap which is in bad shape, so I would like to use a proper fit 1" cap. Local autozone does not carry a 1". Any suggestions where to get one or other options? Thank you guys, you always have the answers. -T.J.
-T.J.
So you do not have heater box circulation?
If you have a heater box, just as easy to get the bypass tube and hook it up proper.
post-39486-0-29432700-1386427269_thumb.j
post-39486-0-44329000-1386427295_thumb.j
Edited by daron
I don't see where crosson9 has stated whether he has sidedrafts or a downdraft carb.  If a downdraft, then he has no manifold heating now.  If not then plumb it up as supposed to be.
Edited by jimk
I've used 2 approaches with that- either use a short piece of hose and an internal plug that fits inside the hose,
or run the rubber line forward, then splice into the heater line that goes to the back of the head.  I put a small
restrictor in there, as it's a 'heat leak' but I found that it helped with bleeding the air out of the head.
I've never seen those caps for cooling systems, and using household plumbing on cooling systems would make me a bit nervous.
hth
TobyB, what would be an internal cap? links or pics to give a clear idea. Thanks you all for your input on this!
Also, hose clamps. Some better than others or are they all the same?
Piece of rubber hose and a bolt of your choice that fits...
-Nathan
