looking for a 10 bar oil pressure sender ? Where to buy?
idiot light on dash cluster and to add independent pressure gauge. dont know why they cannot run off same terminal. Are you just looking for a broader range of pressures? or are you looking for a low pressure warning light/gauge? I know race shops, Summit, etc, all sell real big warning lights that will kick -in at 7 psi, 10 psi and 15 psi. OT, but pertinent to gear-heads: A lot of guys with E 36 engines are getting the warning lights because the oil pump gear retaining nut has a nasty habit of backing off on the 6 cyl. engines, resulting in very quick total loss of oil pressure and usually the loss of the engine. It happens so quickly that without low pressure warning light , driver is unaware until catastrophy. If anyone has read this far, and you own an E36 generation 6 ( not sure of exact engines) make sure you have that nut tightened and then dented so that it cannot back -out.
