should fuel line be replaced?
I have the interior stripped and am wondering if I should run a new fuel line from tank to engine and get rid of the plastic one. What size?
TIA
Good question. I am at the same stage on my restoration. I was planning on either a metal line or steel braided hose. I am curious what others think.
i replaced mine with some aluminum tubing from summit. i first tried to used the stainless hardline but it was too difficult to bend and route it in the same place as the plastic line. i went with the aluminum tubing and its easy to bend and should hold up for a long time.
matt
sort of seal itself off to prevent much fuel leaking out. Of course if you aren't planning on ever having a fire in there, go ahead and use whatever you want to.
