Ball Joint Puller/remover Help Please
mickem02
That's one of the toughest rod ends I've ever had the (dis) pleasure to pull apart.
And they often fail, just to add insult to injury.
I have a relatively generic Old Forge puller that I wedge on there, get a bit of
pressure against it,
then whack on the side of the arm- that usually does it.
If it was mine, I would replace it while I was at it...
I purchased this tool for working on my classic mini, but have since used it on numerous other cars. Very stout. I use it with my electric impact wrench. Works like a charm and does not damage anything.
+1 with this style of tool. Never failed for me on all kinds of joints on all kinds of cars. Even used it as a small puller on other things.
I've not had much luck with the long style puller - too wobbly. The shorter item in the pictures above are easier to control, but I remember winding on a LOT of pressure and wondering whether the tie rod or the tool would pop first. I'd wear safety glasses and be VERY careful.
  • 1 month later...
