Fuel/air choices...
Okay, so it's come to the point where I want to decide if I'm going with FI or carb. I have narrowed it down to a complete 320 EFI transplant, or dual sidedraft Webers. Now, around here, the junkyards have shit for BMWs, so I'd be stuck buying the setup from someone, which would be hard to find and expensive? Also, is it difficult to install?
On the other hand, as this is as more of a fun car than a daily (though I want it to be reliable), the dual sidedrafts would be damn cool.
Help!
-Patrick
A very simple injection set-up would be the 318i L-Jetronic. It is much easier to install and tune...
But for all out HP, nothing beats Webers, short of programable injection...
Especially if you want to be reliable, L-Jet is ok but only for very low boost which isn't much fun. L-Jet would be easier to upgrade to programmable later though, but K-jet is cheap and simple to setup for boost.
but adapting for performance when using it on a 2 liter engine is very difficult.
Use L-Jet manifold, fuel rail and fuel pump from an E30 318. Add a bigger throttle body, different injectors and a MegaSquirt brain and you have a completely programmable system that will flow more air (=more HP) that you can _properly_ tune to deliver performance and driveability. Big bonus, you can do the whole bit for <$350 (with EFI brain).
Cheers!
John N.
MegaSquirt'in
this before and has a bunch of jets in stock. that way you are paying for labor and not parts. Might turn out cheaper, but you'll have to find people that know what they are doing.
steve
