fender rollin'
Can anybody refer me to some posts on here about properly rolling the fender lip, or have any information they can re-list? Got some rubbing issues....TIA
you can use a large crecent wrench on the lip
a baseball bat
any number of hammers (watch out for flyin rust)
etc
the trick is to beat/bend ONLY the lip, not slip and hit the inside of the fender leaving you with a large zit on the outside...
good luck,
b
I used a piece of steel pipe and a heat gun.
Heat the area to prevent the paint from cracking and roll the pipe across the top of the tire. Do this a little at a time and increase the angle every pass. The hardest part is getting it started, goes easy after that.
They do make special tools for this, and some shops rent them out. Even the local CCA chapter here has one members can borrow for free.
