Anyone Install Intermittent Wipers
al
I saw someone mention using the e30 stalk. I have a 73 and the switch is missing from the dash. I also have the blinker switch on my right side. I guess that's how they came...
Is it easy to wire up and does it stick out more?
Thanks for the advice :)
Bosch makes a 'programmable' or 'learning' wiper relay.  You'll have to wire it up yourself, but it's only a few wires.
Here's one source for the relay.
To operate, turn the wipers on to the intermittent position.  After the wipers complete a full sweep turn the wipers off for the desired length of time.  When you turn the wipers back on to the intermittent position the relay will remember this interval.  To change the interval simply repeat the process.
at the risk of revealing my total lack of electronic prowness to the great masses, reviewing the two intermittant relays listed above suggest that it is meant for cars already having an intermittant relay.
what would it take to make these work on cars without intermittant wipers in the first place?
