window goes bang
window on '76 2002 will not go up to fully closed position (1/2" short)- took interior panel off and lubricated all visible parts- still makes bang at the top position and then stops (seems to slip down as well). any ideas? thanks.
These wear and cause just the problem you've described. Try to find a good used one -- someone here should have one for a reasonable price. You're supposedto be able to rebuild them with a Mercedes rivet kit or something, but I've not done it.
Hope that helps.
-Dave
Colorado '71
