Wheel hunting...
I'm looking to go with some better looking wheels on my 74 sahara... Would kill to see some pictures of different wheels etc etc :) especially of anyone with 15's and larger.. how big can we go without rubbing issues?
Momo Basketweaves in 14 x 6: these are the Rotas: standard.jpg and these are the Momos: standard.jpg good luck with search. remember: offset is really important: ideal offset for 2002 is 25-28mm. That would not require much fender rolling at all.
offset for all 2002 wheels.
1 5.5 wide wheel will require a different offset then a 7inch wide wheel.
My vote is for the 15x 6 alpinas but they take a bit of massaging to make them fit.
Still available new (even though they have been out of production for 10 years) from walloth and nesch in germany.
As far as the wheel bearings and steering geometry are concerned there is only 1 correct offset. The additional rim width would ideally be added equally on both sides of the rim with the offset remaining the same. Whether or not you have an equal amount of room on the inside and outside to widen the rim is a different story and so the offset might need to change. It's easier to add flares than to move the strut....The wheel bearings will see different loads and the scrub radius and kingpin offset will change. Does this matter in the real world? Depends how the car is driven and how sensitive the driver is.
URL: http://homepage.mac.com/mgold/PhotoAlbum29.html
See photos P7260095.jpg and P7260096.jpg at the URL below for some 15x7 offset 24 wheels (BMW E30 Style 10). The tires are 195/50-15. Clearance in the rear is fine. Inside clearance in the front is fine. Outside front clearance required a little fender rolling/stretching.
If by rubbing "issues" you mean "problems", stay clear of E21 320i wheels (offset 18), wheels wider than 6 inches, wheel offsets outside 24-30 mm, and tires wider than 195 mm. Good tire sizes are 195/60-14 and 195/50-15. Bottlecap wheels (14x6, offset 35) work with 195/60-14 tires.
It's possible to go outside those limits, and it's been done many times, but you'll have to experiment to see if it works on your car.
With any of the 13's or 14's available the wheel housings look so empty.. those Rotas sure look nice though! I'd like to maintain a 5.5-6.5 width...
I'm going more for a modern "pro touring" look..
