What to use as cleaning solvent for spray gun?(nt)
I use the reducer for the paint I am spraying. Wipe out cup, run a little reducer through gun, dump out reducer, take off air cap and needle valve put in cup to soak in a little reducer, remove cup, squirt a tad of reducer into gun. Then use pipe cleaners to swab out gun, using reducer as necessary. A plastic ketchup bottle as sometimes seen in a deli or restaraunt makes dispensing the reducer easy. Not much reducer is needed at all.
Removing most of the paint via mechanical means is the way to go, the reducer just does the clean-up and loosening of the paint.
That tip was picked up from Len Stuart of autobodystore.com. Works like a charm.
