dumb question about alternator warning light
Hey gang, silly question. When the "L" indicator stays on, does that mean it's draining the battery, or putting a charge on it? thanks!
Basically means there is voltage going from the battery to the alternator (and therefore the rest of the electrical systems).
Matthew Cervi
'73 tii
Here are the possibilities based on what I've run into in the past (I'm sure there are others, too):
1. Alternator itself is dead
2. Ground or positive wire from alternator are broken/loose
3. Voltage regulator is dead (tends to cause a weak glow to light rather than bright light)
4. Wires between regulator and alternator are damaged
5. Poor connection at battery
I recommend looking for the simple things first (loose or obviously broken wires). Then try bypassing the voltage regulator (disconnect the 3-wire plug from the VR and jumper the blue and black wires--if the light goes out then the VR is bad). Next take the alternator to a parts store, most will check an alternator for free. If all the above is OK, then start looking very closely at wires. I ended up having to make a new harness between my alternator and VR because of a broken wire.
Matthew Cervi
'73 tii
