my 02 is sick...
it sounds like a motor boat & it back fires & there's no power at all...i think i'm not getting a spark on one of the cyclinders...i dunno yet..i'll have to check it out tommorrow morning...
also the it idles really low..like at about 100rpm also..i'm surprised it didn't die at that range...
it was running fine on the weekend & today..grr.
any thoughts of what else it could be?
TIA
i have had similar symptoms and thought my 02 world was crashing, and it turned -out to be loose plug wire ends, usually at the dizzy, sometimes on the plug. real easy to check- could be zero dollar fix. just a start: sounds like an ignition oriented problem. good luck
coz i havent changed the plugs in about a year or so..
yeah thought my 02 was crashing as well...coz my other e36 is in the shop for transmission problems & now this..grr..ahehah
Pull the plugs and clean the carbon off with a
brass brush. Keep the brush and a spark plug
wrench with you in the car until you figure out why it
is doing this. That way you won't be stranded
somewhere.
