A short summary of an afternoon spent repairing a rusted Hofmeister Kink... Its a tough area to work due to all of the bends and lack of access...
I am taking care of the rust in my car's body and like many 2002's the side quarter window seals were not changed when they should have been.
The problem-
post-40298-0-02886700-1383183495_thumb.j
The first cuts and one spot weld to remove the first portion-
post-40298-0-22545200-1383183542_thumb.j
post-40298-0-07758500-1383183588_thumb.j
The second portion removed-
post-40298-0-23523900-1383183634_thumb.j
Patch one-
post-40298-0-81322400-1383183725_thumb.j
Patch one welded in with the last bend left up so as to provide access to weld and grind within the channel-
post-40298-0-33544600-1383183781_thumb.j
Ground welds,bent the fold down, and then welded the fold into place. Leaving the fold open on patch one was the key to the whole repair...
Positioned patch number two-
post-40298-0-62967500-1383183843_thumb.j
Welded in and cleaned up. Did alot of the final metal shaping with a hand file-
post-40298-0-50680700-1383183901_thumb.j
Sprayed some primer on for protection until I sand blast it and really protect the kink-
post-40298-0-30858400-1383183948_thumb.j
Still needs some final touch up put it was getting late and had to call it a night.... Hope this helps some people. I was very fortunate that the rust had not compromised any of the outer defining structure. With well placed cuts my patch number 2 required minimal shaping other than a slight bend down the length with a slight crease running top to bottom at the center...
EDIT- sorry all the pics are sideways.... On my laptop they are correct but when uploaded they are not. A little frustrated with the picture upload as the first time around I attempted to just embed a link to my google drive but the forum disallowed that...
Edited by pilotnbr1
74 tii
"I know just enough to be dangerous"
I am beginning to accept the fact that metal only lasts for only a limited number of years no matter how much "love" it gets.  So I guess it is just a question of time before we will all have to fix rust problems like this -- or have someone else do it $$$.
Question: how did you fill the gaps around patch #2?
Thanks for the great photos.
'71 MGB - sold   '74 2002 - sold
'89 XR4Ti - sold  '94 Miata R Package - sold
'73 tii - restoration project - sold
The biggest gaps around patch number 2 were not all that big- but there was alot of variation to the gap size around the patch because I did not spend that much time cutting the outline of the patch. I read a quote somewhere "if you can walk across it you can weld it" - it has some truth.
I am just learning welding myself but what I have found when it comes to welding is that the size of the gap is not as critical when compared to the thickness of the metal- So for example I would much rather bridge a big gap when welding rather than go from thick good metal to thin rusted metal. I have found that if i go from thick to thin suddenly the weld puddle will burn through and make the bead unpredictable. In this particular case I just did a bunch of spot weld and jumped around alot to control heat.
Additionally nice clean metal on both surfaces to be welded is far more critical- it is super annoying to have one side give you a nice good arc but the other side just pops and you don't get good penetration.
My welder is just an Eastwood Mig-135 running 75 argon 25 co2 with .025 wire. I love this welder, it is cheap, and has infinite variable control for power and infinite variable speed for wire speed. Has plenty of power- for this job was on about a 3 out of 10 for power and it runs off 110 volt plug.
Other tools for anyone interested were
-drill with bits, spot weld cutting bit, carbide burr for grinding
-4 1/2 inch electric angle grinder running metal grinding disc and flap discs
-3 inch electric high speed rotary saw - cheap harbor freight and works great!
-Eastwood air high speed metal saw- another favorite of mine for only $40
-center punch
-body hammers and dolly set
-vice
-autobody magnets
-hand metal file
-optionally I used a Speed Blaster abrasive media gun and a syphon feed blasting gun to remove paint
-For patches was just a sheet of 20 gauge mild steel
-Weld thru primer to protect the welds and beneath the plug welds
-cutting oil- get more life out of bits and saw blades
-of course all the associated hearing, eye, body protection, fire extinguisher...
Edited by pilotnbr1
74 tii
Here is the right side all media blasted...
post-40298-0-62528900-1383258702_thumb.j
post-40298-0-88422900-1383258771_thumb.j
I decided to fix the hole below the kink first-
The cut-
post-40298-0-79874400-1383258888_thumb.j
The patch traced it on some scrap paper,cut, then bent in vice using adjustable wrench as a brake-
post-40298-0-25074000-1383259010_thumb.j
Welded in with initial grind-
post-40298-0-03884300-1383259086_thumb.j
The heat caused some shrinking so had to do a couple rounds of primer, sanding, and then some hammer off dolly metal bumping.
Here is a shot after some sanding-
post-40298-0-89906000-1383259268_thumb.j
Got it leveled and primed-
post-40298-0-25986900-1383259372_thumb.j
Still needs some touch up work around where the kink out bevel meets the lip of the quarter panel...
Back to the kink. I decided to make some access cuts through both layers of metal in the kink and then bend the tabs up.
post-40298-0-28308600-1383259471_thumb.j
Rust was a little worse then I initially though and will have to replace a little bit of the side wall within the channel.
post-40298-0-34898600-1383259559_thumb.j
Formed the patch, once again with just a vice, hammer, and pliers-
post-40298-0-69259800-1383259602_thumb.j
Patch in place ready to be welded-
post-40298-0-73976100-1383259669_thumb.j
Got most of the welding done but then ran out of mig gas...
post-40298-0-86754200-1383259708_thumb.j
Obviously more grinding to be done....
Shortly after my 3 inch cheap Chicago Electric Harbor Freight metal cutoff tool died.. The cord shorted right where it entered the grinder. I will fix it but with no gas and then the cutoff tool down it was a sign to call it a day.... TO BE CONTINUED....
Edited by pilotnbr1
74 tii
