Gasket For Oil Cap
Henryn02
Newbie question... Is the gasket for the oil cap necessary?
Yes. Without the gasket there is not enough pressure against the cap to hold it tight and it will fall right off. Unless you have some kind of aftermarket cap, but I imagine it would have a gasket, too.
Usually, yes.  I'd advise having one.  If it then leaks, remove it.
Um, John--removing the oil cap results in a big mess  :D  ....ask me how I know
Now, when the gaskets get old they start to leak. I have tried bending down the spring-loaded tabs in the metal cap to apply more pressure, but that doesn't always work and sometime messes up the cap. I have seen folks put two gaskets in to make it seal, as well.
--Fred
--Fred
'74tii (Colorado) track car
'73tii (Fjord....RIP)
--Fred
Fred,
Im sure you are correct. I have not noticed the gasket before. I will check though.
Walter,
(1973 Fjord Blue 037) Vin 2588314- Build date February 6th, 1973- delivered to Hoffman Motors NYC February 8th.
Quick 'n dirty help for worn oil (and gas) cap gaskets:  take the polyethelene lid from a deli container, butter tub etc and cut a gasket from it, then install under the existing rubber gasket.  It'll seal better, and in the case of the gas cap, make it much easier to remove...
cheers
  • 4 years later...
If they are NLA then I would be cutting one from a rubber sheet. I think the whole caps are available, you could get one and swap the seal if you are attached to your old cap.
rtheriaque wrote:
I grabbed the cheapest oil cap from Blunt a while back and just pulled the new gasket off the plastic cap that came in the mail when mine was leaking a bit. I swapped it into my original cap and haven't had an issue yet. It was like $3.
-Ryan
05/87 M3 Hennarot
04/71 2002tii Baikal
I had this problem with my gas cap--it was very hard to turn, so I made a second gasket from the lid of a deli food container (most any polyethylene lid will work).  Much slicker than the rubber gasket, and in the case of the oil cap, will put additional tension on those old spring clips to hold it on tighter.
