Efi Idle Valve Sucking Oil?
tashakes
I have been having minor issues, among other things with fast idle (1800-2000 rpm).  In an effort to fix other stuff, I noticed the last time I took out the idle valve to clean it with carb cleaner, the idle smoothed over at 800-900 rpm, which is way better.  Also, it now starts at cold without having to modulate the throttle much.
When I cleaned it, the cleaner comes out black a couple of times till it comes out clean, so I am thinking that it is sucking oil (the engine uses about 1 quart every 500 or so miles) and the stuff inside the valve gets stuck.
Is that indicative of worn valves?  Or would it be something else?
TIA
76 BMW 2002 Arktisblau M42 5 spd - Born 5.21.76 - daily money pit
06 Aston Martin V8 Vantage 6 spd - garage queen *  73 Mustang Convertible 351C
15 VW Touareg V6 Executive - daily driver * 23 Audi e-tron SUV (wife's)
Really need more to go on to accurately determine the cause of oil consumption, but it's not likely that you're consuming 6qts. of oil every 3000 miles via the valve seals. I believe you could remove all 8 of them and not suck that much oil. If your crankcase is vented correctly, it's probably overhaul time.
Budweiser...It's not just for breakfast anymore.
Avatar photo courtesy K. Kreeger, my2002tii.com ©
