Nose Section Removal
joysterm
Have searched the site and have had not any luck in finding any reference to removing the nose section of  a '02. I am parting a 69 and would like to know where to make the necessary cuts to remove it as a salvageable piece.
Any advice or tips would be very much appreciated. TIA
Edited by joysterm
Easy- cut it off on the car side, everywhere.  So you leave a small lip of inner fender, a short chunk of front frame rail, etc.
And if the fenders aren't worth saving, leave a bit of the upper tab on them, too.
When you go to use it, you'll trim these back to thin strips, then slowly and carefully remove the last of it.
And the car that's getting the nose will have little strips of its old nose left on it, and then peel them off too.
It's not too hard- time- consuming, but pretty easy.
