Can You Convert An Auto Pedal Box?
bmwbabe
I am looking to convert my 1976 automatic 2002 into a 5 speed manual. I have been looking for a late model manual pedalbox but I was wondering if it is the same housing so that I can just switch out the pedals?
Thank you
Aspen
I did.*
Cheers,
*I didn't ;-)
Ray
Ask me about my E10 320i's!
'73 320i /M2 2.5; '85 ///M635CSi ; '73 320i ugly car; '99 AMG C43
While any thing is possible, I would think you would be better off finding a good manual pedal  box.. They are out there. In order to do what you want to do, you would have to find a manual pedal box anyway for the parts needed for the conversion.
I am also gathering all the parts needed for an automatic to 5 speed swap. I found a good pedal to to use. In order to convert an auto pedal box, you need to attach the clutch master cylinder as well as the clutch pedal and springs and bushings and shaft to the pedal box. I would think you would be saving a lot of grief by finding a good manual box. Maybe one that needs a rebuild but not rotted out.
Edited by peterschop
Just as a caveat in your search for a manual shift pedal box:  The pedal boxes on 2002s with VINs below 1665200 are different from the later ones--the clutch pedal return spring mechanism/linkage is quite different--and prone to wear and failure.  That's why the factory changed the design.
And of course 1600s all had mechanical clutch linkages, so that pedal box won't help you at all...
Yeah- I think I did exactly that- the original pedal box was swiss cheese, but no- one wanted the auto box, so I stuck the
parts from the manual into the auto, and off I went.  At the most, you'd have to relocate the support bracket-
but I don't think it was that involved, even.  The bushing on the auto brake is wider...
Oh, right, I remember, duh.  The auto box has no provision for the clutch master mount.  So you have to cut
the reinforcement off the manual box, weld it onto the auto one, and drill the holes.   With a template sitting on the
bench next to it, it's not too hard.
hth
I probably should have picked up a fresher box, but repaired mine instead.  Silly, maybe, but kind of fun and now it's done.
pattern
patched
If you do drill holes to convert, you will also want to add a piece to thicken the master attachment point
Now that's some pretty fancy fabrication!
thank you.
makes me want to go put a little door on it...
One man's grief is another man's joy!  ; )
...on a good day anyway.
