Tips On Cleaning Engine Aluminum
mdh
Getting ready to replace the engine and I decided to clean her up first. Just painted the block but I am not sure what to do with the aluminum. It looks like someone may have painted some of it at some time and there is a bunch of oxidation. Any tips on how to get it back to the way it looked without damaging anything?post-43183-0-64868600-1381812922_thumb.jpost-43183-0-25572600-1381812993_thumb.jpost-43183-0-64106700-1381813040_thumb.j
Soda blast it... Essentially use baking soda in place of abrasive sand in a media blaster. You can then rinse with water in order to clean it up.
1974 Grey European Market BMW 2002
1976 Yellow BMW 2002 "GOLDENROD" SOLD
1972 Yellow Austin Mini 1000
A bunch of Bikes...
Go to Harbor Freight and get yourself some  toothbrush sized wire brushes.
Too many cars.
that explains the wood floors... haha...
you can totally soda blast in your driveway, or even in a sink. invest in a small compressor.
Trust me. Seriously, I have spent more time cleaning and polishing aluminum then I care to admit. This will be the best solution that fits around your demands. the correct finish is attained by sending them off to get tumbled, but it sounds like you don't want to disassemble and simply want it cleaned... therefore this is just about your only option that wont scratch or damage your covers.
A bunch of Bikes...
I sometimes use WD40 and blue shop paper towels. Works wonders for cleaning off old grease and grime off your engine. Spray it on, work it in, wipe off. Repeat. Don't know if it will take the paint off. Maybe with some small Harbor Freight wire brass brushes and WD40, you can remove the paint.
I chuck the cone shaped wire brush in my 1/2 drill and see what a half a horse will do, hasnt left a scratch and cleans it up great, manis, lids and blocs, eqwally well, use a brass tooth brush and Carb cleaner for the nooks
Happy Trails to u~ Dave Miller
76 Golf~Rhiannon~BM Mascot~*~97 328is~Silver Ghost~*~68 1600~Wisperin Beast~*~70-02~Bumble Beast~*~76 02~Beast~
Keep smilin all the way
Blasting cant be done, no garage, no compressor.... This is a driveway "restoration" and my m10 lives in my living roomattachicon.gifIMG_20130910_013005.jpg...
If that were my situation, i'd put a pan below, get the comet from under the sink, and both brass and regular toothbrush bristle brushes, and go to town. Rinse with a spray bottle. Repeat.
 Good luck,
 bob
71 2002
85 M635
89 327is
98 M3
17 days later you will have a clean engine, ignore gentle brushing and bash the sit out of it
