Efi Conversion Pics Please
1968_1600
I had Ireland Engineering fab one for me. I sent them the original parts from the 318i cable and they used what they needed to make my new one. It has worked fine since 1998.
EDIT I did have to make a stop arm (basically a long L bracket that bolts to the brake booster) to hold the lower end of the cable housing.
Edited by Mike87
Good Luck,
Mike (#87)
check out fink built... I copied his pretty much.  Zenon has a good one too.  The problem is the TB and the accelerator pedal travel at different rates.  I used an L shaped piece of aluminum with the little L on a bolt near the front of the booster.  The middle of the L is the TB cable and the end of the L near the car is where the accelerator rod attaches.  I had to cut the rod in half and rebend the end.
Works pretty good other than i cant get the car started as I think I burned the fuel pump up...
FOR SALE-----74 2002tii 2782194 Turkis, Megasquirt, Korman road sport springs, Bilstein HD shocks, 13" FPS Bottle Caps
