kfish help needed, desparate
Today, I was tinkering with the kfish pump.
Pressure on #4 was about 1/2 the spray pattern as #1.
Swapped injectors....still weak on #4. Problem must be in the pump..
..removed the 6mm hex nut on the top (for #4). Gently pulled out the
valve to inspect it (as per the Bimmer article...).
...then I drop the damm thing...bounces somewhere in the engine
bay...rolled away into some unknown, unreachable spot!!!!!!!!!!!
If anyone has a Kfish pump that is just for parts, drop me a line
please.
jim s
73 tii
