Spark Plug Color, Please Look
zinz
Can y'all take a quick look at this plug and tell me if I'm too rich, too lean, or just about right?
Set up:
NGK BP6ES plugs gapped to 0.033 with a couple 100 miles on them
Weber 32/36
Stock compression pistons
292 cam
IE dizzy with Petronix
Header
Timing unknown
Plugs cleaned/regapped during recent valve adjustment
The Weber is off the car and dual Solexes will get fired up tomorrow. I've installed new plugs with same gap
I've always thought this Weber ran rich, but black spot is only seen on the outer rim and the electrode looks good.
All four plugs looked the same.
Thanks for the input
Ed Z
post-42878-0-10383200-1381557173_thumb.j
'69 Granada... long, long ago
'71 Manila..such a great car
'67 Granada 2000CS...way cool
...forgot to add... Red Coil
One curious thing was that after the valve adjustment it it didn't idle very smoothly. I rechecked the plug gaps, all the wires were snapped on. I made a small idle screw adjustment which helped, but didn't solve it.
Never checked the timing... I suspect my issue lies there.
Any recommendations on a timing setting for the new Solex 40 DDHTs ? I bought a Ti dizzy with proper advance curve for duals, but will start things off with my old IE dizzy to keep the variables to a minimum.
This is my first attempt at dual carbs and have read a LOT, so hopefully things will go smoothly.
