Will 320I Visors Fit A 76 02?
campbell53
I have 2 visors that aren't great (drivers won't even stay up). Replacements (OEM or otherwise) do not seem to be very prevalent. It appears that visors from a 79 320i are still available. Would these transfer over with little no no modification?
If not does anyone know where to get 2 show quality visors?
Those 320 visors should fit your '76 unless you've replaced your original rear view mirror with a much larger one from a 320 or early 5 series.  It's easy enough to measure the 320 visors vs the 2002's for length.
You should be able to make your original sunvisor stay in the up position by tightening the small chrome screw on the vinyl part of the visor.
Grind the hinge down a bit spin the clasps 180 degrees and drill a new hole, careful, not through the car.
Don
Edited by beammmer
Don
Don - those don't look like E21 visors.  E30, perhaps?
Not sure I was told what car they came from, It has been removed from my memory.  I have since changed back to a new set of 2002 visors found on ebay.
Don
Don
