'71 Brake Booster and trans trouble
I am first time '02 owner....1st time BMW owner too.
Can the brake booster be rebuilt? If not can I buy a new one?
Trans grinds gears in 1st and 2nd unless shifted very slow. Hyd clutch seems to be working well. Is it common for the syncros to be bad on 1st and 2nd gears?
thanks,
DLG
The booster is available new, but fezzzominally expensive. But they hardly EVER fail- are you sure it's bad? If so, a good used one should be a fraction of new- since they hold up so well.
The early transmissions have weak and wear- prone synchros. It's a 'feature'. You can swap for a later one (or a 320 5-speed, a REALLY worthwile swap if you drive distances) or just learn the fine arts of heel- toeing and double- clutching. After a while, it gets to be a challenge, and then you don't have to loan anyone your car!
hth
The 2002 tranny is prone to have bad synchros, especially after a few decades. Good used ones are available for less than $200.
I do not think the booster can be rebuilt, but they are available used for a very nominal fee.
