Adjusting Clutch
DakarDoug
Actually the very, very early 2002s had mechanical clutch linkages that were adjustable.  And 2002s with VINs below 1665200--with the coil spring pressure plate vs diaphragm spring--have hydraulic clutch linkages that are adjustable via a variable length pushrod between the slave cylinder and the throwout bearing withdrawal fork.  After that VIN the pushrod doens't have the threaded adjustments.
