Tii Cold Start Valve Bypass Button
schoir
There have been a couple of mentions of bypassing the cold start relay and hooking up a manual switch on the inside to trigger the cold start valve on a tii in recent threads.
Is there a DIY or step by step on installing one of these switches available?
Regards, Maurice.
It looks a bit like the photo in the link below.  The switch with the red label "SCHNELLERPISSER" (upper left) is for the cold start valve in Jynweythek Engineering Lemons tii.
http://www.flickr.com/photos/jynweythek/7681634382/lightbox/
williamggruff
I think you have a loose wire.
Good to see the emergency oxygen cylinder, tho.
Cheers,
Ray
Ask me about my E10 320i's!
'73 320i /M2 2.5; '85 ///M635CSi ; '73 320i ugly car; '99 AMG C43
Cheers,
You may have also noted the absence of the steering wheel and shift lever.  It's a totally drive-by-wire setup.
williamggruff
There have been a couple of mentions of bypassing the cold start relay and hooking up a manual switch on the inside to trigger the cold start valve on a tii in recent threads.Is there a DIY or step by step on installing one of these switches available?
Did your cold start relay die? That's why I did it--those tii relays are too damn expensive (current price for a 61311354686 is ~ $ 236.86). Pretty simple, just a couple wires, a fuse and a momentary push-button switch. In the winter I would just push it for a second while the car fires and then release. Fab up an angle bracket to mount the button and find a place to mount it. Under the dash on the left side works well, unobtrusive.
--Fred '69 & '74tii
Edited by FB73tii
--Fred
'74tii (Colorado) track car
'73tii (Fjord....RIP)
Cheers,
In the unlikely event of a water landing, the emergency oxygen cylinder is to be used in conjunction with the red emergency flotation noodle.
Edited by williamggruff
williamggruff
--Fred '69 & '74tii
Fred:
Yes, my cold start relay died, again.  It looks like the circuit board's solder traces have flaked away in three or four places and I am going to attempt a repair.  Soldering in a strand of wire on top of the board looks like it might make this particular one whole again.
Here is a photo of that circuit board, showing the three sections that have flaked off.  I have already cleaned those spots in preparation for the solder bridge on strand of wire in the spots indicated by the green arrows.
post-45192-0-78992300-1381188871_thumb.j
In case it doesn't I'd like to have a back-up solution such as the one you suggested.
Regards, Maurice.
Edited by schoir
--Fred '69 & '74tii
That's less $ than a set of tires, and it will last 30 years.
1973 tii, agave, since 1992
1973 tii block 2763759
1967 Mustang GT fastback, since 1986
1999 Toyota 4Runner, 5 speed, ELocker, Supercharged
My cold start button is just to the right of the red ignition switch. I spent my $236.86 on other car parts. FWIW, I'm lucky to get 20 hours out of a set of tires. Notice original emergency flasher button at bottom of instrument stack. Brake line pressure gauges above that. Original shift knob from my '73tii. And a bunch of non-BMW parts. No emergency oxygen tank, though :)
-FB73tii
post-36969-0-46633600-1381202804_thumb.j
Edited by FB73tii
--Fred
