Grooved Vs Needle Pilot Bearing
eurotrash
Ok, so I have an interesting question.  I am building a motor.  My '75 crank had a toasted thrust location and I had to use another, of unknown vintage.  I have a new sleeve and needle bearing set.  The new crank has the grooved ball bearing type pilot.  Here in lies the question..
item 18-19 show the sleeve and needle:
http://www.penskeparts.com/DiagramsMain.aspx?vid=47140&rnd=03192010
.. the crank has the 32mm I.D.needed for the sleeve, that accepts the needle bearing set.
I was under the assumption that the sleeve exists to adapt the crank to accept the needle bearing..
Is this accurate?
this leads to the question, does the needle type take a cover?  I can't tell from any of the diagrams.
anyone have pics?
Thanks, m'friends.
(O=o00o=O)
Use the later ball bearing type... They still use that style today! There were longevity problems with the needle bearing style. There was a very good reason they updated them.
Tom Jones
BMW mechanic for over 25 years, BMWCCA since 1984
66 BMW16oo stored, 67 1600-2 lifelong project, 2 more 67-8 1600s, 86 528e 5sp 564k, 91 318i
Mom&Dad's, 65 1800TiSA, 70 2800, 72 2002Tii 2760007 orig owners, 03 325iT, 12 328iT
Hey Tom, do the sealed ball bearing type require the cover?  I can't tell.. seems protective at installation, but maybe I'm over thinking, as usual.
(O=o00o=O)
Correct, if you have the sealed bearing type you don't need the covers. Though, id they're there I usually leave em' in place with the new bearing; who knows if the next pilot will be a non sealed type. Hate having to tell the customer they need parts the last guy left out....
Tom Jones
I had to replace mine last Fall when I had to rebuild my cylinder head.
Make sure you save the sleeve. I had machine shop to press out old needle bearing and press new one into the sleeve and then I pressed the assembly with hamer and brass punch into crank.
post-43112-0-63255300-1380561558_thumb.j
Part Number Brand / Description / Restrictions List Core Your Price Qty Select 11211276551
11211276551.jpg Ina OEM
Clutch Pilot Bearing/Bushing; Caged Needle Type
1 per car. $18.00   $16.06
$16.73 SALE
Is this accurate? Yes.
this leads to the question, does the needle type take a cover?  I can't tell from any of the diagrams.No
anyone have pics?
Thanks, m'friends.
76 2002 Sienabraun
2015 BMW f10
