Weber Dcoe Progression Holes
downhillwolf
Hello,
I have a long lasting problems with my dual Weber 40DCOE19 in the range 2000-3000rpm.
Now i have looked at one 2002 with alfa 40DCOE44/45 conversion and i know that problem is in the progression hole arangement and size. I have 55f8 and it's not good since his 50f15 is ok.
Can someone picture his progression hole arangement and what size did he enlarge them.
Best regards
Blaz
Best regards
Blaz
It was meant for my friend with 40DCOE44/45 with 50f15 idle jet.
Since i know that AlpinA used this type DCOE twin carburetors(40DCOE19 and 45DCOE19) so on 40mm and so the 45mm carbs.
I still dont know how did they work it out, was 70's gasoline so much different or did they not use 2000-3000rpm range?
Best regards
Blaz
The key to locating the progression hole is . It must centered over the throttle plate at Idle so as soon as you crack open the throttle the hole is exposed . The gas we get now is called e10 10% alcohol . Idle jet and idle mixture needs to be richer especially with a bigger cam.
Edited by 75duce
75 2002 M20 alpina rally clone
77 320 EP race car
91 e34 M5
78 Ford e100 van 300 ci 6cyl 4 speed
The key to locating the progression hole is . It must centered over the throttle plate at Idle so as soon as you crack open the throttle the hole is exposed . The gas we get now is called e10 10% alcohol . Idle jet and idle mixture need to be richer expecially with a biger cam.
Yes i know that we have alcohol inside gasoline, but we still get better gasoline don't we?
Do use have drilled progression holes? Can you attch picture of that?
Best regards
Blaz
No the gas we get is  not better. Gas with alcohol needs a richer mixture . No I did not need to drill new progression holes. Shine a light down the carb and look at the holes from above also take a close up pic and post it up . If the plate is not centered over the first hole you need to drill a new one there . You may also not have your idle mixture screws turned out enough. set it real rich just for a test  and see what happens at 2- 3000rpm while driving .
My car with a sport engine needs a 60 f8 idle jet and a rich idle mixture to get good clean performance in the 2-3000 rpm range .
Idle jets should really be called pilot jets because you are on them at 2-3000 rpm cruising along just off idle.
a interesting test is to remove the main jet stacks completely and drive the car carefully and slowly you will be able to see just what the
idle jets are doing and were the main jet starts tipping in because the engine will die.
My car runs weber 3x dcoe 45 #9 and has non removable progression hole covers so i cant show the holes but there are three and they are located just  how they need to be with the throttle plate centered over the first hole at idle.
Edited by 75duce
77 320 EP race car
91 e34 M5
Thanks for that tip, i have in stock also 50f8 and 55f8.
I have a picture of progression holes:
Mine(this is the same carburetor as in my car)...
From my friend...
I don't want to drill progression holes since there is no way back...
The carburetors from my friend was from 2.0L alfa romeo engine made for racing...
Best regards
Blaz
That's not a progression hole, that's a leak!
The holes you have look familiar.  You can actually tune where they kick in by modifying the
throttle plate- drill small holes in it to get it to close more, or file the edge off it to get the
progressions to be exposed earlier.  Or even bend it, but that seemed like a hack to me.
You CAN epoxy up old holes- there was a thread years back about doing it, but I couldn't find it.
In your case, if you can come up with some repeatable way to figure out where the throttle plates are when your
engine goes soft, you'll be miles ahead. I had a data logger on the shaft of the race car, so it was
pretty easy- get it to reliably stumble, mark the number, then in the pits with the engine off,
get the data to match.  It found several problems, including a bent throttle shaft.
