Megasquirt Relay Board Edis Injector Wiring
austinmf
About to wire megasquirt up with a relay board running edis.
I am confused on the injectors. Some diagrams look like two banks of two and others show pins 1-4 running each injector. Power is coming from two of the 4 hot leads.
Should the injectors be controlled or fired individually?
By board is labeled with two banks of two but me thinks the engine will get too much fuel.
FOR SALE-----74 2002tii 2782194 Turkis, Megasquirt, Korman road sport springs, Bilstein HD shocks, 13" FPS Bottle Caps
You should start by telling us what model of megasquirt you are using.
Typically 2 injectors are connected to one 5 amp fuse and the remaining 2 injectors to another 5 amp fuse on the relay board.
The relay board supplies the +12Volts, the ECU does the switching by grounding the negative end of the injector coil.
As Harv said, injectors don't care which end of the coil is grounded.
Here is a link that may clarify this for you.
http://msextra.com/doc/general/ms2external.html  and another good link  http://www.extraefi.co.uk/drawings.htm
Edited by allbim
Too many cars.
