white smoke - new question
Saw the thread below re: white smoke on decelleration, but how do you check to see if the booster is full of brake fluid? Are there any other ways to check if that is the source of the smoke?
you'll have to unbolt the master cylinder. Not too big of a deal. just two nuts. if you see fluid there, then the MC will need to be replaced and booster cleaned. If that is the source of the white smoke, then that is a good thing. Otherwise it's coolant.
a leak down test will let you know if that is the case.
steve
Or just pop the vacuum hose connection off and stick something in there to check (something soft, like a piece of small diameter tubing or your finger - you don't want to damage the diaphragm).
