1970 Bmw 1600
granth
1970 BMW 1600 for sale, SoCal OC please contact me via email: granthe@pacbell.net for test drive or any other questions.
Car is not perfect, please keep your negative comments to yourself, but very fun to drive, all the guts have been replaced.
http://brakefade.com/files/pics/Auto/bmw_1600/album_2013/
http://brakefade.com/files/pics/Auto/bmw_1600/1600_build/bmw2002_R&D_16litre_feb2009.pdf
Stainless Steel Braided Brake Hoses $90
WHEEL BEARING KIT - FRONT $70
Wheel Bearing kit - Rear $45
19mm Rear Wheel Cylinder $52
230mm Rear Brake Shoes - Ferodo $100
Brake Booster Check Valve $17
22mm Front/22mm Rear Sway Bar Set $390
Bilstein sport front and rear $450
IE Stage 2 springs $250
Strut bent more camber $50
Rear Subframe Mounts for 2002 $125
Motor Mount Plate for 2002 $25
Front Subframe Reinforcement Plate $45
URETHANE STEERING COUPLER $20
Ball Joint 2x $64
Tie Rod Assembly 2x $116
Track Rod $80
Steering Idler Arm Bushings $67
Front Urethane Bushing $79
Rear Urethane Bushing $69
Strut Brace $175
Exhaust system with 1600 stall header $550
Aluminum Radiator $325
MB Coil $60
Re-wire battery trunk mount with brace $225
Pertronix Ignitor $75
12mm x 65mm Long Wheel Stud $160
Diff Bushing $40
Rebuilt 1600 motor 3k miles (attached PDF) $3000
Weber 38/38 carb $250
Year: 1970
Make: bmw
Model: 1600
