Competition BMW 1602
I am about to build a 1600 engine for competition use in a class restricted to a max of 1600CC. I plan to increase the compression fit a hot cam etc. I am looking for information and suggestions on the possible configurations and parts availability/sources etc.
I believe the 1600ti had an optional cylinder head (118 casting#) with a bigger bore for a 300 cam. I don't have the compression specs at my fingertips right now. That and DCOE sidedraft 40's might be part of the ticket. What is the motor number and the car's vin? As for the crank, do you have 6-bolt or 8-bolt? The 8-bolt makes the retrofit of a 2002 clutch kit easier, although I believe others have had the 6-bolt flywheels can be re-drilled to accept the pins for the 8-bolt clutch kits. Drop me an email and I'll get back to you sometime when my schedule slows down.
Derek
dscott@dplus.net
The donor engine is from a 1975 european 1502, It has a 118 cylinder head. The competition car currently has a 4.11 Quaife LSD, Twin 40 Webers on a 2 litre engine.I am living in Ireland (Europe) and I plan to compete in events with a class restricted to a max of 1600 cc. The type of events will be mostly track type with some tarmac stage rallies
The 3 main issues I now have are,
1. Availability/source for High Compression pistons
2. What Cylinder head should I use?(I have spare E12 heads)
3. Camshaft?
Thanks everyone for replies so far
