Door Card Replacement
Mike_R
I have to say, as a long time forum member, the search function has been my least favorite tool.  And the new forum makes it harder!   Anyway I have some Aardvark door cards & I would like to find a good instructional post for updating & replacing door cards, including exterior door handles, & the other common issues in the door mechanics & latch area.  I have upgraded the door brakes, but I think there is a lose item in the door based on a rattle I hear upon closing the door & I understand a common issue is in the linkage for the door latch/lock.  Bummer the PO cut the door vinyl to install speakers, so I will just have to cut the door cards to match.
Thanks in advance
75 2002: weber, ANSA, lowered, 14" wheels, new engine, new suspension, rust free & square.
That rattling is likely the lock rods. Cheap easy fix. You need 6 of the isolator grommets  they are about 50 cents a piece  ask for  52208238999
Also replace the vapor barrier with either Ocella cloth or your favorite plastic and the doors will sound nice
www.BluntTech.com
FAQ Supporting Vendor
 Sales@BluntTech.com
I'm doing my doors soon, where do I find Ocella cloth?
Yes, there WAS skin on my knuckles before I started the repair...
Acella cloth might still be available from BMW, Maximillian Importing, BluntTech. I've used thin clear plastic garbage bags, drop cloth, or shower curtain with no problem.
Part Number 51951924961
Part Name 8-TRIM FOIL
MSRP $36.17
http://realoem.com/bmw/partxref.do?part=51951924961
John in VA
MSRP $36.17
Thanks John!
Best replacement for acella cloth (which is actually plastic) is Visqueen--or any heavy polyethelene sheet.  Most lumber yards have it--usually by the foot.
is there a type of caulking one could use if the plastic sheeting method is used? rather not get spray adhesive all over the place.
I've not had problems getting the spray adhesive where it's needed, but BMW has been using a butyl caulk rope for at least the past 15 years.  Talk to all the owners of E39s & E46s that have soaked carpets & mold from the detachment of the inner panels from this caulk.  Heat it up a bit before you press the plastic onto it.
Edited by John_in_VA
John in VA
Blunt, do you have these available?
1979 e21 318 (sold)
1975 Inka (sold)
1983 e21 320i (sold)
1974 Polaris (sold)
1975 M42 Swap (work in progress)
