Weekend Dual Carb Conversion
jdeitch
Finally some time to work on Remy. Removing single 32/36 Weber and installing dual Dellorto DHLA 40 side draft carbs. Using IE intake manifold and water bypass kit. Redline crossbar linkage.
BEFORE
post-39742-0-73235600-1379130289_thumb.j
INTAKE REMOVED
post-39742-0-46115200-1379130381_thumb.j
WATER BYPASS KIT INSTALLED
post-39742-0-63793200-1379130451_thumb.j
TEST FIT MANIFOLD
post-39742-0-84517100-1379130512_thumb.j
TEST FIT CARBS
post-39742-0-47425200-1379130558_thumb.j
1975 Polaris 2002 (RAT 02E), 1962 mini Cooper S
1994 Land Cruiser - expedition vehicle, 2012 VW Touareg TDI.
2002 restoration blog - http://rato2e.blogspot.com/
Nice! It's a project near the top of my list. So are u planning in using the mechanical fuel pump? How about ignition? The 2 things I am going to do are upgrade the ignition to a crane xr700/3000 and msd blaster coil and then go to a mechanical fuel pump.
2016 BMW 535i M Sport
1964 Volvo Amazon Wagon
http://www.project2002.com
This is just part of my top end makeover.
Dual carbs.
292 SCHRICK cam.
MSD ignition.
My MSD billet dizzy is on its way to me from Terry Tinney. (Terry modifies MSD distributors designed for air cooled VW to work in the BMW M10 engine.)
I will have a complete MSD CDI ignition system.
MSD pro billet distributor.
MSD 5520 ignition box with rev limiter.
MSD blaster 2 coil.
I plan on using the stock mechanical fuel pump.
Edited by jdeitch
Cool , I run my stock fuel pump with a Filter King to regulate fuel pressure , Gotta love them Dellortos , fit a wide band O2 sensor into your header it will make tuning much easier & remove much of the guesswork.
1970 4 speed 2002 (Daily driver/track car )
1974  Hybrid powered twin cam engine, Pig Cheeks , ( now a round tail.) Getting ready to Sell
Dual carbs.
292 SCHRICK cam.
MSD ignition.
MSD blaster 2 coil.
Does he have a web site sounds like an interesting ignition package.
72/2002 Inca
72tii/2002 "Apple"
70/2002 "Five "
73/2002 "Freeda"
2007 Lotus 7 Replica
2011 Ford xr6 Ute
85 E30 325
70 1600-2 "Orange"
Yes Sir. I plan on adding a wide band when I redo the exhaust. (I'll have most of the exhaust system out when I do the 5-speed/LSD conversion.) in the meantime I have a portable/battery operated 5-gas analyzer.
I have installed modern CDI ignitions on several older 'points' type ignition project cars. They provide better idle, performance, emissions and economy. I originally bought a dual point Mallory distributor from a FAQ member and was going to replace the points with a electronic pickup and a Mallory ignition box. After buying the Mallory dizzy I had a hard time locating the parts to adjust the timing curve. (I wanted this feature to help dial in my dual carb setup.) While searching the FAQ I learned that air-cooled VW distributors are the same as 2002 dizzies except for the drive gear. More FAQ research revealed Terry Tinney. Very nice guy. Good communication. Fast turnaround. Terry modified the MSD VW pro billet distributor I sent him. He machined/installed a longer shaft to mount a BMW drive gear. (I also provided the gear) He did not develop nor sell me a 'package'. I'm sure you could discuss options with him. There is a ton of information on the web regarding CDI ignitions. I like using YouTube to research many items. Several good videos on MSD components. I will post details when I do the ignition install.
Terry Tinney
Performance Motors
925-447-1820
terry@terrytinney.com
Edited by jdeitch
Looking good but you should install soft mounts between the carbs & intake , howdit run ?
Fuel filter too, very important  I run my filter king filter/regulator after the fuel pump with the stock BMW filter before the pump.
Edited by LimeySteve
Jeremy I'll beg to differ been using soft mounts for 35 years on different builds & not had a problem with fuel frothing etc which I believe is the inherent problem with hard mounting side drafts . What is your take on them & why disapprove, I'm always open to persuasion.
