Radiator choices in M20 swap?
What are all you fellow M20 nutcases doing for radiators? I was thinking a custom aluminum one but the budget doesn't allow that, anyone have any info on that and on which electric fans are good. TIA!
Curtis
as i did...I went with a VW Scirocco rad. its super wide and super short. Cost me $110CDN, brand new, and available virtually anywhere. Good thing about this is that if you get it to fit, you can always upgrade later, because dragsters love the Scirocco sized rad. Look in Summit or Jegs and they always have aluminum something something special kick-ass blah blah 'Scirocco' rads. I *think* that InstructerBill used a Scirocco rad as well.
I had the car on the track this weekend in hot temps, and the coolant temp stayed super cool. Having said that, it does NOT stay cool in traffic...I haven't put on a rad fan yet (lazy). I think I have some air in there though too...
Matt
'72 02/m20
I beat the hell out of the car this weekend and never saw the temps raise above half scale. This is a good one-- I think.
I used a combination of 325i hoses, 2002 hoses and another one that I got from napa autoparts (number slips me-- I can get it if you need it)
Since the diameter of the hoses are slightly different, small couplings must be made-- simple really.
I bought a fan switch that screws directly into the scirrocco rad but I have not wired the relay yet so for now I remove the fuse when I don't want it to run (insert "Sanford and Son" theme here)
I am using a perma-cool fan. Works great- should last long time.
A full write-up is in the works, but I don't have the tech know-how to put it into script. Anybody who wants it should contact me directly.
I am also going with the Scirocco radiator. Should have the core brace/rad mount fabricated this weekend. Still about a month away from cranking her over as many other projects are still to come, ie roll cage, paint, etc.. etc..
