High Beam Indicator Not Woring
peterschop
Mine does!  But only when I turn right....
As far as the high beam indicator, I`ve been looking at a wiring diagram.  If your high beams work, then the problem is likely between the connector at the firewall and the light itself(including ground).  On mine most problems like this were dirty/corroded connections and one wire with a break in it.  Keep checking things and you will figure it out, only so many wires on these cars.
Edited by Johnson
`70 Black 1602 - My Beater
http://www.bmw2002faq.com/topic/135517-saving-a-1970-1602/
`03 GMC S10 - Fiance`s Truck/Parts Hauler
