Are there specific wiper motors depending on year of production?
Edited by mo's72tii
<p>69 (M2 Project-stalled); 72tii (a) Taiga/ m42 swap in process;91 E30 vert; 2013 Porsche Cayenne GTS; 65 Mustang fastback 500hp+ resto mod in process ;72 Porsche 911s project; 70 2002 M2 2.5L getting closer
There are three wire and five wire wiper motors, but there's a way to wire one to the other's wiring harness.  Also, the three bolts that hold the wiper motor to its linkage is turned 180 degrees between these two wiper motors, but again you can re-drill the linkage or just swap the linkage when you swap motors.
If you need to adapt a three wire motor to a five wire car, I did a column on this; drop me an e-mail and I'll send you a copy.
cheers
  • 5 years later...
When it comes to searching I am digging the ‘search by author’ refinement at the top of the search form, just under ‘content search’.  Very often I can visualise who was involved in a good discussion on here and this really helps to narrow it down (along with the ‘all of my search terms’ option).
rtheriaque wrote:
