rain gutter molding
Any tips on re-installing the new trim on the rain gutter. Some rust issues were addressed before paint work; would it be a good idea to put some type of sealer in the molding beforte installing it?
TIA
First it is best if the gutter is dead on straight and formed just like it is on the car, so if you mail order one,make sure it is not bent in shipping ( another long story).
Then I gently start at the curve and make sure it is lined up front to back, clip it on over the curved part by holding it almost upside down and 180 degrees up, so that you can just catch it on the body, then after that you should be able to just with your fingers, snap on the back and the front portions. Try not to force it. I've taken a few off too, sort of the reverse, except I get behind the clipped part and with a rubber pallet and a square block of wood release it back to curve and hood tocurve until I can lift it off, have fun,
