320 engine and tranny swap
I am attempting to put a 1982 320 eng/trans assembly in my '02....have a few questions as you can guess. Anyone out there done this before?
Distributer spins the oppisite direction adn uses a differant firing system. Al in canada, told me about this Volvo Ignition box. It plugs right into the 320I dizzy and worked wonderfull. All it is, is a black box with five wires coming out of it. Infact I still have all the parts here from my 71. If you want I will sell it to you for $20+ shipping. Email me off the board.
Andy Rattley
easterratt@hotmail.com
IF you are converting to carburetion. sounds like you are not. the tranny mount should be the same IF you are using the four-speed 320i tranny (just use the 02 mounts/crossmember. if youre using the five speed, just use the FAQ five speed article (see index) as your guide!!!!
-Rob
You will need to use the 02 oil pan and oil pump as the 320 pan does not clear the cross member. Also you will need to use the 02 water pump and fan as the 320 water pump and fan protrude into the radiator space. Peter
I will keep the waterpump in mind (and the fan which I had to use since the old one was wrecked. Regarding the oil pan...I check it today and I think I am ok...I have my fingers crossed that the slight clearance I have on the drivers side is OK... but again, thanks for the information. Any tricks you know of for figuring out how long to make the driveshaft?
