Trying to remove rear brake flex hoses
What am I missing in trying to disconnect the rear brake flex hoses? I disconnected the rigid line at the back of the trailing arm thinking that the flex hose would then be lose, but that wasn't it. I can't seem to get to the front end of the hoses because the sway bar is in the way.
The factory manual just says to "detach brake hose" like it should be real easy. What am I missing here???
I'm just trying to remove the subframe and would hate to get into a lot of on-car disassembly that can more easily be done when the rear suspension is out.
Matthew Cervi
'73 tii
the rigid lines screw into the metal female connection of the flex lines at the subframe. The metal part is a tight fit in the subframe, may need a small persuader to free the flex line from the subframe. Hope I am looking at the part you are questioning.
URL: http://www.lovingeveryminuteofit.com
Are you going to reuse the flex line? If not just pull on it really hard. It's possible that rust could be holding it in there.
Taking it apart at the front end of the back line is a pain, but it is possible, just takes 15 minutes per side because you can only move the wrenches a 1/8th of a turn each time.
I just removed the sub-frame out of my parts car last weekend. The lines came right off, but I did take the sway bar off first. The e-brake lines were more of a pain :-(
Took 20 minutes to get the first parking brake cable out (of course I'd never disassembled the rear brakes before so I had no idea of what I was doing).
Matthew Cervi
'73 tii
So far, other than my rusty subframe (left side is almost gone at the subframe bushing) everything just looks really dirty, not rusty. I'm replacing the subframe with a good one I pickup up a while back along with all the bushings, diff seals, etc.; I'll also clean and paint everything. A nasty project because it is all so dirty, but long overdue.
What are you doing on Pikachu?
Matthew
