Upgrade Brakes?
chito
So I read the upgraded brakes article and am a little confused on something.  It says to buy the front struts from a tii for a non tii car for one of the upgrade options.  But every time I try to look up online for tii front struts it never has the spindle on it.  From reading on here I know they use different spindles.  I've read that if going with bigger 15" rims it is better to swap to the bigger spindles and bigger hubs.  Can you buy these new from anywhere? I want to upgrade the brakes and use 15" wheels so what parts do I need exactly?  Can I use an e21 320i spindle and tii front strut? I would like to use all new parts if I could.
Chito,
Don't believe the spindles can be separated from the strut, as in they are a single piece. I did the big brake upgrade on my base car last year with tii struts, 320 hubs and IE vented & drilled rotors. Added spacers to widen the tii calipers to fit the wider rotors. Probably overkill on a car that isn't raced or auto crossed (actually barely driven), but the improvement in the braking was dramatic and I don't live in fear of having to make a panic stop anymore.
'71 02 - parts car with not many parts left
'73 02 - weekend toy and money pit
'74 04 - sold in '91
'03 325iT - for trips and bad weather
'03 50cc Honda Scooter - for my 2 mile commute
'06 50cc Honda scooter - wife's commuter
The 2002 strut is a tube with what's traditionally called a 'spindle' welded to the bottom of it.
Then you get a hub from an early 320.  Are you, perhaps, referring to the hub as a spindle?
Yup. The tii one has bigger bearings.
They're nice, but not more than about $200 nice.  I don't know where the 15" wheel thing came from.  It doesn't make any sense.
The wheel can be 13, 14 or 15" and have both the same offset and overall diameter, as well as weight.
I raced 'wrong offset' wheels for years on the standard struts- they do fine.  You DO have to maintain them
a bit more religiously for racing use, but that's just regreasing every couple of weekends.  For  a street car,
you'd want to do it every time you changed the pads, but that's not exactly 'high maintenance'.
What USUALLY happens to them is that they get overtightened,  and then burn up.  Unlike a Murrikan car, you
actually want them the absolute slightest bit loose, for safety.  So get them 'just' tight, so there's no rocking top- to- bottom,
then loosen them until you can JUST feel play.
This has worked for me for over a decade...
hth
you do not need tii struts to run 15in wheels or do the ventilated brake upgrade.  regular struts work just fine.  there isn't any issue with the bearings at all for street use.  for heavy track use, just like toby said, you just to maint on them more often.
+1 to all toby said regarding the definitions of spindle and hub...
3xM3
http://www.iemotorsport.com/bmw/2002-suspension-steering/02bil023.html
most are like this they just look like tubes no spindles on them. I did notice on their custom coilover kit they have spindles on the bottom of those. So do the billies also come with spindles?
Your links are messed up. I fixed them for you.
The bilsteins are just inserts into the stock struts.
Edited by Cru Jones
chito...no offense intended, but you do not appear to have any idea what parts you are looking at or what the definition of the various parts are.  have you ever worked on cars before?
on left in this pic is a bare strut.  the other two have inserts in them.
lots of struts
this is the spindle end of a strut.
this is a hub.  it goes on the spindle.
and these are struts with inserts in them and hubs on the spindles.
now go back and reread the faq article on upgrading to vented brakes.
Edited by mlytle
3xM3
Ok so a strut is a different piece and they don't sell those no more, right? So whats the deal with the custom coilover kit. Did they make there own spindle to weld on there?
you have been an faq member for 3 day...suggest you do a bit more research with the search function and then come back with any q's.  there are tons of threads on brake upgrades and ways to convert struts to use adjustable height collars.  (2002's come STOCK with coilover front suspensions..that is what a mcpherson strut is.)
3xM3
