Please post pics of screws of Under steering shroud (cover)
Can someone post some pictures of the 6-8 screws that attach the under steering column part to the body ? I am somewhat certain some of those screws are used to ground something. I have 4 long bolts and that is it. there are some other holes from more screws.
ps. all this is to solve a lingering problem with my 320is steering wheel horn. I hear just little noise from the horn instead of a loud and clear horn as it was with the bus wheel.
Thanks
If the horn is behaving erratically, check the little spring loaded metal slider that comes out of the back of the steering wheel (easiest to get to if you pull the wheel). Mine was all torn up after 30 years, and I had to replace it.
does not appear that grounding is a part of this installation
The four long screws simply hold the top to the bottom. The
two screws towards the driver stabilze the lower part to the
steering column. The two screws towards the firewall hold
the underdash panel.
