Pics Request : Billie Hd'd & 13 Rims.
jayamasaki
So I bought some billie HD's, and some 13x5.5 rims, just wanted to know if anyone has some pics of :
Billie HD's with 13" wheels, stock height
Billie HD's lowered (show what you got as far as drop goes 1" , 1.5", 2" etc)
let me know what springs your running as well, and if they are cut.
my main inquiry is to see how low people are running with Billie HD's & 13rims, and how it looks stock with this particular combo.
thank you in advance everyone !
1968 BMW 1600 Chmnx White
1976 2002 Parts car
2003 f150
60% of the time, it works every time!
My car has Bilstein HD's, IE stage 1 springs. These pics are with the 13 x 5.5 turbines.
I always do it right the second time.
1970 2002 Chamonix (Fiona)
1976 2002 Chamonix (Blanche), '73 2002 Colorado (Nemo), '72 2002 Riviera, '74 2002 Atlantik, '71 1600 Sahara (Binkley) all sold
Great pics, throwin my turbines on today and lookin like they will fit nicely, curious what tires you are running Stu?
Happy Trails to u~ Dave Miller
76 Golf~Rhiannon~BM Mascot~*~97 328is~Silver Ghost~*~68 1600~Wisperin Beast~*~70-02~Bumble Beast~*~76 02~Beast~
Keep smilin all the way
I thought the sports were smaller than the HD's.
Stu, how many inches are the IE stage 1 springs lowered ? Also, are yours uncut ?
Lowering inches are relative, be very open minded when you read published drop measurements.  These measurements are taken using BMW published factory specs when the cars were new.  Now plenty of cars are running 40 year old saggy springs.  I've actually had people who's car was raised with a new set of "lowering" springs because of how shot the original springs were.
Not only that but there are other variables to consider.
-Rear spring pad size.
-Front DOT spacer removed or kept on.
-production run of spring (for example the last batch of IE stg 1 and 2 springs have been shortened slightly when compared to older batches)
and lastly, the measurement for ride height should be taken from the rocker adjacent to the wheel well and not from the top of the wheel well arc and the tire.
When did you shorten your springs? I got my stage 1's in the fall/winter
1973 2002Tii (Pacific Blue)
1984 911 3.2 Carrera (Platnum Metallic)
2009 328xi (Black Sapphire Metallic)
2010 Mazda Speed3 (Black Metallic)
FYI, the stock BMW springs used on 68-72 US spec cars cause the car to ride about an inch lower than the stock springs used from 73-76.  Reason?  Federal bumper height requirements that began with the 73 model year.  BMW met the height requirements by using a taller spring, and the 2.5 mph bumper requirements (73 only) with stronger brackets.  The 5 mph requirement (74 on) were met with the big aluminum bumpers and shock absorbers.  Thus a cheap way to lower a 73-76 car is to use stock springs from an earlier one--saves cutting coils.
I'm currently running H&R springs (lowered my '73 about 1.5" from the stock tall springs, after removing the aluminum spacers) and Bilstein HDs, along with stock 5jx13 factory alloys.  Does help the handling, especially when paired with larger sway bars.
cheers
I believe the stage 1 springs lower the car about 1 inch.  They are uncut; and I kept the aluminum spacer in the front.  I like a level ride.  The front is still a bit lower than the rear, with the spacer
They are Falken Ziex 205/60 x 13.
