Correct Headliner Part Number For Sunroof
nbcbird
Go to solution Solved by BLUNT,
Could someone verify that the correct BMW part number for the headliner WITH SUNROOF is 51.44.1.804.085?  Not sure what the SSD and ESSD connotations mean--the other number is 51.44.7.480.140.  Does the sunroof version also come in one piece (with the installer cutting the roof opening) or is it precut?  Imagine it would be a lot easier to install entire liner first without cutting for sunroof.  Thanx.
  • Solution
sunroof version comes pre cut .. youll need a meter of fabric for the roof panel
here are the numbers
51 44 1 804 085 x1  headliner sunroof
51 95 1 817 302 x1 yard material
non sunroof headliner
51447480140
www.BluntTech.com
FAQ Supporting Vendor
 Sales@BluntTech.com
Thanx Blunt.  Has anyone installed the non-sunroof version and then cut the opening for the sunroof?  Imagine one with a pre-cut opening would be a lot harder to adjust.
you cant do that  The bows are all different   its not as hard as you read about  With patience and lots of clips youll be fine
www.BluntTech.com
 Sales@BluntTech.com
Thanx again.  Never thought that the bows are different.
Just to clarify the bows are sewn in different locations on the 2 headliners  The bows themselves may or may not be the same  Im not certain
www.BluntTech.com
 Sales@BluntTech.com
