How Do You Mount Your E30 Bottlecaps?
e30 6x14 et35.  I have stock unrolled fenders.  I anticipate needing a small spacer in the front based on research on this forum. I will be mounting 195/60/14 tires.
I was just wondering what people with this setup use to mount the wheels?  I have oem steel and oem alloy lug nuts.  will these work?  How about oem length bolts?  I am ordering 4.5mm spacers.
I am picking up the wheels up tomorrow so I will find out soon enough, but a search here came up short so I figured I would get things rolling in case I need to order something to make these wheels work.
thanks for any help
1973 2002Tii (Pacific Blue)
1984 911 3.2 Carrera (Platnum Metallic)
2009 328xi (Black Sapphire Metallic)
2010 Mazda Speed3 (Black Metallic)
Use OEM alloy lug nuts; the taper is the same for 2002 factory alloys, E21 and E30 factory alloys.
Suspension still needs to settle post lift, but the tires dont rub on routine driving. Tonight i will give it a good run and go lock to lock steering. Love the tires, great ride with no steering feel loss. I am keen to see how they stick.
Mounted without spacers using oem bmw alloy lugs.
post-43382-0-37568800-1376592443_thumb.jpost-43382-0-62140500-1376592489_thumb.j
Look great, put a spacer in and you will be rollin fenders, sometimes easy is best. Puttin polished e21 turbines on tomoerrow for my snow tire rims, yes shes on a salt restricted back roads only diet, 175-70s and no clearance issues. Tired of my black steelies, she deserves new shoes for her 38th birthday, still a hottie.........................
Happy Trails to u~ Dave Miller
76 Golf~Rhiannon~BM Mascot~*~97 328is~Silver Ghost~*~68 1600~Wisperin Beast~*~70-02~Bumble Beast~*~76 02~Beast~
Keep smilin all the way
I had my car on jacks today to replace the motor mounts. While in the air, I checked the tie rod end clearance to wheel. It was close, maybe less than 1/8" but it should never rub the tire. At least it hasn't yet and I have done spirited driving with Michelin Pilot Exalto A/S 195/60R14 tires. My tires should never touch the tie-rod ends unless I have loose lug nuts or wheel bearings.
