Yeah, i've just been enjoying taking my time and tacking the little problems one by one. I'm in no rush, especially since it's winter! I'm getting so close though!
Hows' everyones' swap cars holding up? Tony, I can't wait to see yours when you turbo it!!
Cheers.
clutchCTRL!
Move with a purpose.
1991 325iX 4dr/5spd I 2000 323i I 76 2002 - M20/G260 - in progress.
Hey kid it's about time you get your 02 going and driving .. It's been awhile since you started I wannacsay we started around the same time .. Get-er done and drive it man .. How bout some pics of 02 with m20 .. Let's see some progress pics from anybody
progress!! Coming along slowly but surely. Need to finish routing coolant hoses and find a fan that's fits and is worth a dam. Also need to route throttle cable and make brackets. Oh, and I blew up my diff while trying to do a celebratory burnout[emoji28]
Makes me laugh[emoji16] once tax return comes in, car is going out for rabbit flares and exhaust
Sent from my LG-H811 using Tapatalk
Edited by luismpr
Looking good! Yeah I don't think I'll be doing any burnouts till I get a stronger diff sorted oug
Sent from my Nexus 4 using Tapatalk
clutchCTRL!
I am running a 3.9 diff and it's a little too short.  I am thinking 3.64 or even 3.45.  As it is, the M20 in the E30 runs a 3.73 with taller tires.  A 4.44 will basically eliminate 1st gear.
Pierre
O==00==O
69 2002 (M20), 74 tii, 76 533i, 79 323i, 80 732i, 84 323i (S50) 91 318is, 96 318ti (S52), 97 Z3, 02 330i, 03 525iT, 02 R1150 RTP.
Auxiliary Lamp Brackets  Kamei Reproduction Front Air Dam
Yea ,I know its going to be pretty short. I got a good deal on it and figured why not. I would really like to get my hands on a 3.45 but we'll see how everything goes
Sent from a cloud of 2002 m20 burnout pixie dust
I'm just going to drive it easily until I get a rear end/diff setup that's proper for the power plant. The CAtuned setup looks really nice!
I've got my downpipes fabbed up and just waiting on a flex pipe, resonator, muffler, and some more 2.5" piping so I can finish up the exhaust. The cooling system is mocked up, everything looks really good! I don't have space behind the rad for a fan, so i'll do what TonyBeemer did, I've got plenty of space in front of the rad.
I need to tidy up the wiring and get the ECU in the glovebox. What is the easiest way to accomplish this? My first thought was a big hole saw but i'm not sure what others have done.
Transmission Tunnel still needs love but I want to drive it first! :)
clutchCTRL!
That one and jakes setup look awesome but they're pricey.we're gonna need pics of exhaust!;) haha. I started cutting a hole in the firewall for the harness to go through. The grommet on the m20 harness is 2inches so I started drilling with a 2 in hole saw. Should fit perfectly because the actual part on the grommet that seals is 2 inches while the rest of it is larger. Haven't actually done it yet but that's the plan
I just started learning MIG welding with my exhaust. It's not pretty for for "stage one" it'll do! Here's my garage currently.. Messy.. Full..2ea4d5d675c63d7cb02380528f48473b.jpg
Cooling the system setup. Need to grab a pipe this weekend for the upper rad hose. It needs a slight "twist" to get it where it needs to go. I'll take better shots this weekend but I figured this would help with your cooling system mockup.
Using a mix and match of early/late model cooling system stuff to get the cooling system situated.
Sent from my iPad using Tapatalk
clutchCTRL!
What temp sensor are you running in the tstat housing? For the front one
Tony do you happen to know the spal part #? I think I may have the same pusher fan
Luis, the temp sensor is autometer and goes to an autometer gauge to monitor temps closely.
clutchCTRL!
