Tii Master Cylinder Upgrade
Mr Sizzle
Go to solution Solved by tim385,
Hi everyone, well my brakes were completely gone! took it to a brake place, and both the brake boosters on my 1969 were completely full of fluid! so i had them rebuilt!
1200 dollars later :( my brakes are FIRM like a race car! but the master cylinder is leaking into the interior carpet the last bit i need to fix!
i ordered a Ti brake master cylinder from ireland engineering as an upgrade and have recieved it today
probem is i want to install it and when i compare it to my standard master cylinder! this one has 1 too many holes in it!
the original master cylinder has only 4 holes, 2 for inlets 2 for outlets, the new Ti master cylinder has 5?!! what plugs into this 5th hole??
any help would be appreciated
I am guessing that if you have two brake boosters that you have a right hand drive car.
Pretty sure that ti's are lhd only so you have the wrong part.
Edit: actually not sure what you have. Title says tii.
Edited by Simeon
rtheriaque wrote:
LHD master is different to RHD master, look at a diagram for LHD (they have 1 booster) you may be able to block 1 outlet off you just have to find out which one .
72/2002 Inca
72tii/2002 "Apple"
70/2002 "Five "
73/2002 "Freeda"
2007 Lotus 7 Replica
2011 Ford xr6 Ute
85 E30 325
70 1600-2 "Orange"
Also LHD go straight onto the servo so the mounting lugs may be on the horizontal whereas RHD are a bit off vertical.It wont fit , order a RHD one from Jaymic.
Edited by tim385
72/2002 Inca
72tii/2002 "Apple"
70/2002 "Five "
73/2002 "Freeda"
2011 Ford xr6 Ute
85 E30 325
70 1600-2 "Orange"
hmmm dam! i am pretty sure i know which one to block off its just a matter of whether i can and whether it will still fit and work! would be a shame to have wasted 160 dollars :(
thanks for everyones help so far will have to do some more investigating!
 I have a RHD automatic 2002, and the part i bought was the Tii upgrade master cylinder
http://www.iemotorsport.com/bmw/2002-brakes/02tiibmc.html
Tim is right (I have just checked mine). The rhd master cylinder has the two pressure ports on top of the cylinder along with the low pressure ports from the reservoir.
The flange bolt holes are on a slant at approximately 45 degrees. It won't fit. Put it up for sale on this board and someone will take it (maybe not for what you paid).
Alternatively try contacting IE who might on an off chance take it back (though to be fair they don't have to - buyer beware)
If you want to upgrade a RHD you get a E12 master cyl.
Is that 'any' E12 or is it specific to RHD again?
Quite right,one less thing to do if he decides to go Volvo fronts at a later date.I suppose while your changing a leaking master why not change to a bigger one?It seems like 02 owners well we just can't stop at doing one thing, can we?
72/2002 Inca
72tii/2002 "Apple"
70/2002 "Five "
73/2002 "Freeda"
2011 Ford xr6 Ute
85 E30 325
70 1600-2 "Orange"
exactly Tim, i figured i might as well upgrade while im at it, i am actually thinking about the wilwood front and rear upgraded calipers at some stage! will probably have to purchase another master cylinder then anyways hah!
I'm running big wilwoods on the front and vw rear discs on the race car and volvos on front with 320 drums on the back on the street car.No boosters .
72/2002 Inca
72tii/2002 "Apple"
70/2002 "Five "
73/2002 "Freeda"
2011 Ford xr6 Ute
85 E30 325
70 1600-2 "Orange"
