One of those marks on the front pully is TDC. If you have an adjustible timing light, you can figure out how much mechanical advance you have. Basically, you will want as much as you can apply without invoking pinging- maybe 25 degrees or so, max. This means you will need 5-10 degrees static advance (i.e., with the motor not running).
Chris B.
'73 ex-Malaga
The TO mark is TDC.  the ball pressed into the flywheel is 25deg BTDC.  You want 34-36 deg of TOTAL advance.  Unless you have had the distributor on a machine and know EXACTLY what the advance curve is on your distributor (it may be old and worn out, might have been modified at some point in it's life, may be working perfectly.)  You won't know unless you test it.  Setting it by the factory specifications of "timing ball" at some stated rpm assumes that the distributor will be at a very specific place in the curve at that RPM.  There is usually about 20 deg of centrifical  advance in the distributor so I would suspect you should be somewhere around 12-15 degrees BTDC at idle and 32-35 deg BTDC at 3500-4000 rpm.  If you are at 0 at idle you are most likely 12-15 deg retarded but if you put 15 deg into it and don't check your total advance you could be way over advanced at full throttle, have detonation and burn a piston or blow a head gasket.
1970 1602 (purchased 12/1974)
1974 2002 Turbo
1988 M5
1986 Euro 325iC
  • 3 weeks later...
I got rid of the homemade vac tube. Have the timming set pretty well and also the dwell. Idle is just a tad rough at 1000rpm, but may be from the cam, which had been changer. I do not know the degree of the cam but will check when I adjust the valve clearence.
How does your 2002 idle with a 292 degree cam?
Thanks for all of your help.
