320I Front Hubs For Brake Upgrade
djdawson2
Hi,
I'm upgrading my front brakes during the rebuild of my '72tii.  As I understood it, I needed to use 320i front hubs.  I see this listing on ebay:
http://www.ebay.com/itm/BMW-e21-320i-front-hubs-big-brake-conversion-2002-2002tii-used-/121113175347?pt=Motors_Car_Truck_Parts_Accessories&hash=item1c32e86533&vxp=mtr
In his description, he indicates that they won't work on the tii.  Can anyone enlighten me as to why they won't work... and if they don't, what will I need to find.
Thanks!!
Dave
From earlier this month .... should answer your question in length.
http://www.bmw2002faq.com/topic/142538-volvo-brake-hub-issue/?hl=big+bearing+hubs#entry934136
Now that being said, I'd contact Rob (the seller) directly and ask if he has some big bearing hubs around.  The guy has lots of goodies and is one of the only guys I'd trust to do a proper tranny rebuild.
LOL... funny enough that you are answering, as it's your brake kit that I need hubs for.  So I need "large bearing" hubs from a 323i, correct?
Thanks,
Dave
Oh, and I'm also wondering if I can fit the E36 318 lsd diff into a 2002 housing... or only into the 320i housing... following your project post.
Thanks
haha go figure.  The big bearing hubs are just getting hard to keep on the shelf.  If anyone would have a couple sets though it would be Rob.
As for the Diff. as long as the case you're starting out with is not an LSD case then yes it'll fit (with proper shimming of course).
Small world.  All my stuff arrived this week, and all looks fantastic.  The braking on my tii when stock was pretty darn good... I can only imagine what it's going to be like with both front and rear Wilwoods.
My 2002 diff was stock 3.64 non lsd... so I should be good?  That's one part of the project write-up where I'm somewhat concerned... proper shimming of everything to get it put together with proper celarances.  I've seen more than a few "home builds" fail at track events, and I don't want to be one of them.  I'm also not in the mood to spend $2k on a rebuilt diff... seems too pricey.
Thanks again...
